HI
The test mode 1 don`t work. My configuration is blow
write register:
Extended control register (Register 17) : 0x1846
Configuration register 1 (Register 18) :0x810
Basic control register (Register 0) : 0x2110
It means the bit LINK_CONTROL is disable.The test mode is 100BASE-T1 test mode 1
I read the register after i write it, it shows i had write successfully.
but i hadn`t detect the clock signal at TXC and RXC , i hadn`t either detect any data at the RXD[0:3],why?
I am not sure whether my configuration is right.
can you give me some suggestions?
Solved! Go to Solution.
Check EN pin with a scope, the PHY should output TX clock at that pin during test mode.
Bulat
I do not know what is "TJA1105". Can you clarify correct part number?
Bulat
I make a mistake,the type is TJA1100
Bulat
