Subject related to Debug in s32 design studio
SAchary11
Hello All,
I am facing issue while flashing the code in MPC5748G.
I get below error, I am not sure why this error is popping, If anybody has any idea please let me know
I have done the flash and debugged it before, now suddenly this error is appearing
Is it because some exception we are not able to launch it?
stanish
Can you possibly post the details related to this error. (press "Details >> button)?
Have you selected correct debug configuration that matches with the build configuration (e.g. elf file is generated before lunching debugger)?
Do you intend running a RAM based project (debug_ram_pemicro)?
Is your probe correctly detected? Do you use a NXP EVB or some custom board?
This helps to identify the root cause of this error.
Stan
