Re-Transmit frames of S32R274 FlexCAN
Durant-Harden-Irving
I have a question to trouble you, sorry.
Question background:
MCR.B.AEN is set to be 0x0 (Abort disable)
frame 0x400 is transmitted cyclic (20 ms)
The CAN is connected to the car ADAS-CAN( many frames transmitted by other node, e.g. ESP/EPS...)
My question is:
When frame 0x400 arbitation fail, does the FlexCAN re-transmit it automatic?
If yes, how many attempts numbers it re-transmit?
Can I configure theattempt numbers?
Thanks!
MF
