Machine check trap when write ETIMER registers in User mode
592 次查看
phuong_nguyenle
I'm using MPC5744C for my project. Currently, I'm trying to write data to ETIMER in user mode:
        ETIMER_0.CH[0].CNTR.R = 1000; //My code
But Machine trap is fired (status is below pic):
I turned off all MPU mechanism and check AIPS configuration and it is OK. But Trap still happen.
So, Can you help me to find out trap's source?
Which reason can fired this trap?
Thanks!
550 次查看
PetrS
did you also enable User access in the Register Protection module? Set UAA bit of REG_PROT_GCR resister.
Below macro can be used
#define REGPROT_GCR 0x3FFC
#define USER_ACCESS_ALLOWED(modulebaseaddress) (*(volatile uint32_t*)((uint32_t)modulebaseaddress+REGPROT_GCR)|=(uint32_t)(0x00800000))
BR, Petr
550 次查看
phuong_nguyenle
Thanks for your guide. It solved my issue
551 次查看
PetrS
BR, Petr
