Then you need to check the java RTE version: it should be 6.0 or higher, and it must be a 32-bit version. Here is mine:
Hello @Ehsaaan ,
You may try to:
- Goto the folder "..\NXP\AUTOSAR\MPC574xG_AUTOSAR_OS_4_0_92_RTM_1_0_3\os_ts\eclipse\workspace\os_sample_sc1\output\epc>
- Then call "...\NXP\AUTOSAR\MPC574xG_AUTOSAR_OS_4_0_92_RTM_1_0_3\ssc\bin\generator\sg.exe project.epc"
- Then check if the configuration is generated successfully in the "...\NXP\AUTOSAR\MPC574xG_AUTOSAR_OS_4_0_92_RTM_1_0_3\os_ts\eclipse\workspace\os_sample_sc1\output"
Hung
Maybe this thread will help: https://community.nxp.com/t5/MPC5xxx/Help-with-AUTOSAR-OS-running-on-MPC5748G/td-p/1333584
Nam
