MPC5748G RXIMR can receive multiple CAN id?
800件の閲覧回数
Ada_Lovelace
Hi,all
I have use the chip by CAN FD mode.
Then IRMQ = 1, I use RXIMR to receive id,  I want to receive 0x120~0x12F,
So I set the code:
    for(i=0;i<96;i++)
        CAN_1.RXIMR[i].R = 0x1FFFFFFF;
    CAN_1.MB[41].CS.B.IDE = 0;
    CAN_1.MB[41].ID.B.ID_STD = 0x120;
    CAN_1.RXIMR[41] = 0x3F0<<18;
   CAN_1.MB[41].CS.B.CODE = 4;
But It can only receive 0x120, what shoule I change to sovle it?
3 返答(返信)
793件の閲覧回数
PetrS
code looks fine, but do you really have IRMQ=1 and set RXIMR in Freeze mode?
You can check within debugger, when module is put in Freeze mode, a setting of the MB and RXIMR.
BR, Petr
780件の閲覧回数
Ada_Lovelace
Hi,Petr
I debug the project, IRMQ=1,RXIMR[41]= 0xFC00000,
But when I send 0x122, flag could not be set.
768件の閲覧回数
PetrS
for test, try to clear that RXIMR, does it receive all IDs?
Or share your project.
BR, Petr
