MPC5746R analog multiplex ADC reference design
679 次查看
jamesmurray
Contributor V
Is there a working reference design for external multiplexed analogue channels? Particularly I want to see a known good design with low crosstalk between channels and accurate readings.
I have encountered a similar problem as this customer asked about here
https://community.nxp.com/thread/457095
I have not yet tried such a large value for DSD but with a value of 1000, I am seeing at least 25mV errors in the measured ADC count apparently due to crosstalk with adjacent channels. This is with op-amp buffers ahead of the multiplex. Without the op-amps I was seeing up to +/- 500mV of crosstalk !!
If there isn't an existing reference design, can I reach out to an applications engineer to work with me on this?
regards
James
593 次查看
davidtosenovjan
Unfortunately we do not have any reference design for this configuration.
593 次查看
jamesmurray
Contributor V
I added ticket no. 00264904 for this question too.
If possible, I will share any findings back here.
James
