I want to disable the weak pull up in each pad during Power on Reset or RESET.
In MPC5746R, weak pull up of all port are enabled as a default when it's POR/RESET.
After it's POR/RESET, I could disable the weak pull up by configuring the SIUL_MSCR[WPUE].
But, it need to be disabled when it's POR/RESET because it can cause the unwanted output.
Please share the solution if you have for this query.
Thank you.
Kimin
