MPC5674F Bootloader
MPC5674F Bootloader
970 次查看
pyi285
I want to ask something related to the code related to the MPC5634M chip bootloader, so I upload it.
Looking at the link or attached file below, can I know what the code in the SSD_driver file in the MPC5634M_bootloader file does? It's difficult to look at the data sheet.
https://community.nxp.com/t5/MPC5xxx/MPC5674F-Bootload/m-p/1637095#M23401
#MPC5674 #bootloader # MPC5634M #SSD_driver
956 次查看
lukaszadrapa
I can remember that I already sent you the link to SSD drivers for MPC5674F. Then you can find user manual and API description here:
c:\Program Files (x86)\Freescale\Standard Software C90FL Driver v1.0.4\MPC5674_5676R\UM_C90FL_MM_SSD.pdf
The drivers are provided in pre-compiled form to avoid issues with compilers and also these files are usually used by flash programmers.
What it does - it just follows the procedures described in the reference manual like:
Lukas
5 回复数
957 次查看
lukaszadrapa
Lukas
944 次查看
pyi285
I don't have the link above. Could you please upload the pdf file you mentioned and explain in detail what the SSD does exactly?
920 次查看
lukaszadrapa
Just install the drivers and you will find the manual in that folder:
https://www.nxp.com/webapp/Download?colCode=MPC5674F_C90FL_SSD_DRV
907 次查看
pyi285
알려주신 코드로 작성해본 결과 이런 결과가 나왔고, 함수를 사용할 수 없다고 하고, 소스를 사용할 수 없다고 합니다. 이것이 왜 그런지 아십니까?
891 次查看
lukaszadrapa
If you jump into this function, you will see only pure asm code. As we already discussed, this driver is provided in pre-compiled form without source files. So, the debugger does not have details about the source. It's better to only step over these functions.
Lukas
