MPC5643L FlexPWM DISMAP question
zili
Hi, I just recently got my hands on the demo kit and started reading through the example code. There are two questions for the following section of code.
// Switch on all FlexPWM channels
SWITCH_ALL_PWM_ON(M1.uni3PeriphCfg.flexPwmBaseAddr);
// Enable FlexPWMA/FlexPWMB fault protection
FAULT_PROTECT_PWMA_ON(M1.uni3PeriphCfg.flexPwmBaseAddr);
FAULT_PROTECT_PWMB_ON(M1.uni3PeriphCfg.flexPwmBaseAddr);
// Switch off all FlexPWM channels
SWITCH_ALL_PWM_OFF(M1.uni3PeriphCfg.flexPwmBaseAddr);
First, is it required to switch on FlexPWM channels first before configuring DISMAP? It's not mentioned in the MPC5643L reference manual in nowhere. If so, why?
Second, the subfunction of FAULT_PROTECT_PWMA_ON actually clears DISA in DISMAP. However, if DISA is zero, the fault protection is disabled as seen in figure 25-27 and following quote.
The PWMA output will be turned off if there is a logic 1 on a FAULTx input and a 1 in the corresponding
bit of the DISA field.
But the comment of the code indicates it is for enabling fault protection?
Many thanks.
PetrS
Could you please specify which example do you refer to?
I see no reason for switching on FlexPWM channels before configuring DISMAP.
Also as you wrote, if FAULT_PROTECT_PWMA_ON actually clears DISA in DISMAP, then the comment is not correct.
BR, Petr
zili
Please see the following code in the main loop, sections related to DISMAP are highlighted.
void main (void)
DISABLE_IRQ();
// Initializing of clock, reset, core mode etc.
sys_init();
// Initializing wait states in for FLASH read/write
//flash_init_fnc();
// Initialize UART
uart_init();
// FreeMASTER initialization
FMSTR_Init();
// Siu initialize
siul_init();
// Initialize DSPI module
dspi_init();
// Initialize PIT timer module
pit_init();
// Initialize SBC power source
mc33905Config(&sbcDrv);
// Initialize FlexPWM module
flexpwm0_init();
flexpwm1_init();
// Initialize CTU module
ctu_init();
// Initialize eTimer0, eTimer1, eTimer2 module
etimer0_init();
etimer1_init();
// Initialize ADC_0 module with HW offset cancellation
adc0_init();
adc_off_canc(&ADC_0);
// Initialize ADC_1 module with HW offset cancellation
adc1_init();
adc_off_canc(&ADC_1);
// MC33937 Configuration with Double RESET Timing logic
// Since the reset pin is common for both power stages, the configuration
// is done automatically for both PWSTGs in one step !!!
mc33937DoubleReset(&(M1.preDrv));
#ifdef UNI3_1
// Initialize MC33937 driver on 3ph Low voltage power-stage
mc33937Config(&(M1.preDrv));
mc33937Enable(&(M1.preDrv));
mc33937ReadSr(&(M1.preDrv));
if (M1.preDrv.status.sr0.R!=0) M1.faultID.B.WrongHardware = 1;
M1.cntrState.state = init;
M1.cntrState.event = e_init;
#endif
#ifdef UNI3_2
mc33937Config(&(M2.preDrv));
mc33937Enable(&(M2.preDrv));
mc33937ReadSr(&(M2.preDrv));
if (M2.preDrv.status.sr0.R!=0) M2.faultID.B.WrongHardware = 1;
M2.cntrState.state = init;
M2.cntrState.event = e_init;
SWITCH_ALL_PWM_ON(M2.uni3PeriphCfg.flexPwmBaseAddr);
FAULT_PROTECT_PWMA_ON(M2.uni3PeriphCfg.flexPwmBaseAddr);
FAULT_PROTECT_PWMB_ON(M2.uni3PeriphCfg.flexPwmBaseAddr);
SWITCH_ALL_PWM_OFF(M2.uni3PeriphCfg.flexPwmBaseAddr);
#endif
// CTU MRS_O clearing
if(pCTU->CTUEFR.B.MRS_O) pCTU->CTUEFR.B.MRS_O = 1;
// Enable all interrupts
// Ensure INTC's current priority is 0
INTC.CPR_PRC0.B.PRI = 0;
// Enable external interrupts
ENABLE_IRQ();
while(1)
// Reading faults from MC33937 pre-driver - the same pin for both Power Stages
if (GET_SIUL_INPUT_VAL(SIUL_PAD_53))
#ifdef UNI3_1
if (M1.cntrState.readFault)
mc33937ReadSr(&M1.preDrv);
M1.cntrState.readFault = false;
#endif
#ifdef UNI3_2
if (M2.cntrState.readFault)
mc33937ReadSr(&M2.preDrv);
M2.cntrState.readFault = false;
#endif
// FreeMaster polling function, shall be executed on background
FMSTR_Poll();
zili
Hi Petr,
The example is MTRCKTDPS5643L, which comes with the demo kit of 'AN4518 Dual 3-Phase PMSM Development Kit with MPC5643L'.
Thanks.
