Inverter board compatible to use with MPC5777C evaluation board
Ahmed_Abd_El-Hafez
Hello NXP team,
I want to know which Inverter board is compatible to use with MPC5777C evaluation board. [if one intends to use MPC5777C board, which inverter board can be used with it] like MPC5744P with DEVKIT-MOTORGD.
Thank you in advance,
Ahmed_Abd_El-Hafez
thanks Peter, what is the name of the inverter board in the figure you sent?
Ahmed_Abd_El-Hafez
Thank you, Peter. So, what is the name of this inverter board in the figure you sent?
petervlna
