Howto Define a Variable type In Specific Memory Region
758件の閲覧回数
tunayan
Dear All,
I am using MPC5644A dev kit. I have a problem about memory relocation.
Is there any way to define "volatile const" variables in predefined memory region with LCF?
I can solve that issue with below example:
#pragma explicit_zero_data on #pragma push #pragma section sconst_Type const_type ".__Cal_DataArea" ".__Cal_DataArea"    const uint8_T acuc_DC_override_en = 1U;   const real32_T acuc_DC_override_val = 0.0F;   #pragma pop
But i dont need that.  Because with that method , i need to write these pragmas before all variables. I have too many variables in different places. So is there any way to wirite on LCF sth and define all volatile consts to specific area?
Thanks all.
468件の閲覧回数
stanish
Hello Tuna Ayan,
I'm afraid that CW linker cannot distinguish between constant vs. volatile constant.
I'd recommend you to use __declspec(section ... ) instead of #pragma section + push/pop. since it's easier to replace it with macro:
e.g. you can add the statements below into your prefix .h file or into a custom .h file that is included into each source file :
prefix.h
#pragma section R ".__Cal_DataArea" ".__Cal_DataArea"
#define VOLATILE_CONST __declspec(section ".__Cal_DataArea") volatile const
Now in all the source files where you declare a volatile constant just replace keyword "volatile const" with "VOLATILE_CONST"
VOLATILE_CONST char hello[]= "Hello World!";
and all these constant will be placed into ".__Cal_DataArea" section.
Note: If a constant is not referenced in the code you should instruct the linker to avoid dead-stipping this symbol e.g. in .lcf file, FORCEACTIVE { "hello" }
Hope it helps.
Stan
