while (FLEXCAN_DRV_Init(INST_CANCOM1, &canCom1_State, &canCom1_InitConfig0)!= STATUS_SUCCESS) ;
flexcan_id_table_t stfilter[] ={{0,0,0x111},{0,0,0x222},{0,0,0x333},{0,0,0x444},{0,0,0x555},{0,0,0x666},{0,0,0x777},{0,0,0x888}};
FLEXCAN_DRV_SetRxMaskType(0, FLEXCAN_RX_MASK_GLOBAL);
FLEXCAN_DRV_ConfigRxFifo(0,FLEXCAN_RX_FIFO_ID_FORMAT_B,stfilter);
FLEXCAN_DRV_SetRxFifoGlobalMask(0,FLEXCAN_MSG_ID_STD,0xffffffff);
which SDK version are you using? In RTM 1.0.0 the FLEXCAN_DRV_SetRxFifoGlobalMask() and similar functions was updated to reflect ID format too, however still the mask setting is not correct for format other that FORMAT_A.
BTW, for FORMAT_B you need 16 items in stfilter array to fill ID Table completely, assuming default 8 table elements.
BR, Petr
