How can I set dual conversion in ADC command list
956件の閲覧回数
alexanderhu
How can i initial the TCU?Is there any SW DEMO?
820件の閲覧回数
petervlna
I expect you are referring to CTU and not TCU as you are speaking about ADC command list.
Here is the explanation:
Select CMS and Channels which have to be converted in dual-conversion mode.
Make sure your ADC's are in CTU mode.
Peter
3 返答(返信)
821件の閲覧回数
petervlna
Peter
820件の閲覧回数
alexanderhu
Thank you for your help,Pete.The datasheet(MPC5744PRM.pdf) is hard to read.
820件の閲覧回数
davidtosenovjan
Could you specify used device? Thanks
