EEPROM ECC Error injection in MPC5746R
855 次查看
renjithr
I need to test EEPROM for single bit/multi bit error using ECC in MPC5746R. I refereed the following post:
https://community.nxp.com/docs/DOC-332668
Using this i was able to generate flash fault. Similarly I want to test EEPROM for single bit/multi bit error.
I tried modifying the address range of flash block to EEPROM block in the above sample code(since it is emulated flash eeprom). But I am not able to inject any fault.So please suggest any methods available.
RR
标记 (3)
608 次查看
davidtosenovjan
Hi, you may see almost the same thread here:
https://community.nxp.com/thread/458504
