Hi Lukas,
I have tried this file, without success.
First I had to edit the file because 2 pins were incorrectly numbered (TCK and GPIO_16 swapped) and I added the power pins as linkage bits.
I can now use it for boundary scan testing but it still fails.
It looks to me that the instruction register length does not match the device.
Are you sure this is the correct file for the MPC5746R ?
Hi Jim,
let me check this with responsible team if they are aware of this and if they have a solution. Please notice that it may take some time, so thank you for your patience.
Lukas
