Hello everyone,
I have two different questions about bootloader on MPC5777C.
I generated s-record file and then converted it to 64-bit boundary successfully.
I would like to learn when I should set SIU_RSR[BOOTCFG] pins as 01 for serial boot.
Also, Could you inform me about when I start to send start adress, code length and code data after reset.
Sincerely.
Berat.
