Example MPC5775K UART_with_DMA S32DS_1.0
* Detailed Description:
* Application performs basic initialization, setup PLL to maximum allowed freq.,
* setup clock for peripherals, Setup access right for Masters and Peripherals
* on AIPS_0
* LINFlex UART mode with FIFO transmit using DMA
* LINFlex UART mode with FIFO receive using DMA
* ICache and DCache are both disabled in startup file using CACHE_ENABLE macro.
* You can change the value of the macro at the following path:
* project Properties/C/C++ General/Paths and Symbols/Symbols
* If you change the value to 1, ICahce and DCache will be enabled in startup.
* Test HW:         MPC5775K-356DS, MPC57xx Motherboard
* MCU:             PPC5775KMMY3A 0N38M
* Terminal:        19200-8-no parity-1 stop bit-no flow control on LINFlexD_0
* Fsys:            PLL0 266MHz
*                    Z4 Core 133MHz
* Debugger:        Lauterbach Trace32
*                  PeMicro USB-ML-PPCNEXUS
* Target:          internal_FLASH (debug mode, release mode)
* EVB connection:  J14.2 to P12.6 Connect LINFlexD_0 RXD to main RS232
*                  J13.2 to P12.7 Connect LINFlexD_0 TXD to main RS232
添付
%3CLINGO-SUB%20id%3D%22lingo-sub-1123618%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E4%BE%8B%20MPC5775K%20UART_with_DMA%20S32DS_1.0%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1123618%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E********************************************************************************%3C%2FP%3E%3CP%3E*%20%E8%A9%B3%E7%B4%B0%E8%AA%AC%E6%98%8E%3A%3C%2FP%3E%3CP%3E*%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AF%E5%9F%BA%E6%9C%AC%E7%9A%84%E3%81%AA%E5%88%9D%E6%9C%9F%E5%8C%96%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%80%81PLL%E3%82%92%E6%9C%80%E5%A4%A7%E8%A8%B1%E5%AE%B9%E5%91%A8%E6%B3%A2%E6%95%B0%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E*%E5%91%A8%E8%BE%BA%E6%A9%9F%E5%99%A8%E3%81%AE%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%80%81%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%81%A8%E5%91%A8%E8%BE%BA%E6%A9%9F%E5%99%A8%E3%81%AE%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E6%A8%A9%3C%2FP%3E%3CP%3E*%20AIPS_0%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20DMA%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9FFIFO%E9%80%81%E4%BF%A1%E3%82%92%E5%82%99%E3%81%88%E3%81%9FLINFlex%20UART%E3%83%A2%E3%83%BC%E3%83%89%3C%2FP%3E%3CP%3E*%20DMA%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9FFIFO%E5%8F%97%E4%BF%A1%E3%82%92%E5%82%99%E3%81%88%E3%81%9FLINFlex%20UART%E3%83%A2%E3%83%BC%E3%83%89%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20ICache%20%E3%81%A8%20DCache%20%E3%81%AF%E3%81%A9%E3%81%A1%E3%82%89%E3%82%82%E3%80%81CACHE_ENABLE%20%E3%83%9E%E3%82%AF%E3%83%AD%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A7%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E*%20%E3%83%9E%E3%82%AF%E3%83%AD%E3%81%AE%E5%80%A4%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%83%91%E3%82%B9%E3%81%A7%E5%A4%89%E6%9B%B4%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E*%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AE%E3%83%97%E3%83%AD%E3%83%91%E3%83%86%E3%82%A3%2F%20C%20%2F%20C%20%2B%2B%E4%B8%80%E8%88%AC%2F%E3%83%91%E3%82%B9%E3%81%A8%E3%82%B7%E3%83%B3%E3%83%9C%E3%83%AB%2F%E3%82%B7%E3%83%B3%E3%83%9C%E3%83%AB%3C%2FP%3E%3CP%3E%E2%80%BB%E5%80%A4%E3%82%921%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E8%B5%B7%E5%8B%95%E6%99%82%E3%81%ABICahce%E3%81%A8DCache%E3%81%8C%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20------------------------------------------------------------------------------%3C%2FP%3E%3CP%3E*%E3%83%86%E3%82%B9%E3%83%88HW%3AMPC5775K-356DS%E3%80%81MPC57xx%E3%83%9E%E3%82%B6%E3%83%BC%E3%83%9C%E3%83%BC%E3%83%89%3C%2FP%3E%3CP%3E*%20MCU%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20PPC5775KMMY3A%200N38M%3C%2FP%3E%3CP%3E*%E7%AB%AF%E6%9C%AB%3A19200-8-%E3%83%91%E3%83%AA%E3%83%86%E3%82%A3%E3%81%AA%E3%81%97-1%E3%82%B9%E3%83%88%E3%83%83%E3%83%97%E3%83%93%E3%83%83%E3%83%88-LINFlexD_0%E3%81%AE%E3%83%95%E3%83%AD%E3%83%BC%E5%88%B6%E5%BE%A1%E3%81%AA%E3%81%97%3C%2FP%3E%3CP%3E*%20Fsys%3APLL0%20266MHz%3C%2FP%3E%3CP%3E*%20Z4%E3%82%B3%E3%82%A2133MHz%3C%2FP%3E%3CP%3E*%20Debugger%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Lauterbach%20Trace32%3C%2FP%3E%3CP%3E*%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20PeMicro%20USB-ML-PPCNEXUS%3C%2FP%3E%3CP%3E%E2%80%BB%E5%AF%BE%E8%B1%A1%3Ainternal_FLASH(%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%83%A2%E3%83%BC%E3%83%89%E3%80%81%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%83%A2%E3%83%BC%E3%83%89)%3C%2FP%3E%3CP%3E*%20EVB%E6%8E%A5%E7%B6%9A%3AJ14.2%E3%80%9CP12.6%20RXD%20LINFlexD_0%E3%83%A1%E3%82%A4%E3%83%B3RS232%E3%81%AB%E6%8E%A5%E7%B6%9A%3C%2FP%3E%3CP%3E*%20J13.2%E3%81%8B%E3%82%89P12.7TXD%20LINFlexD_0%E3%83%A1%E3%82%A4%E3%83%B3RS232%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E********************************************************************************%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-TEASER%20id%3D%22lingo-teaser-1123618%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E********************************************************************************%3C%2FP%3E%3CP%3E*%20%E8%A9%B3%E7%B4%B0%E8%AA%AC%E6%98%8E%3A%3C%2FP%3E%3CP%3E*%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AF%E5%9F%BA%E6%9C%AC%E7%9A%84%E3%81%AA%E5%88%9D%E6%9C%9F%E5%8C%96%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%80%81PLL%E3%82%92%E6%9C%80%E5%A4%A7%E8%A8%B1%E5%AE%B9%E5%91%A8%E6%B3%A2%E6%95%B0%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E*%E5%91%A8%E8%BE%BA%E6%A9%9F%E5%99%A8%E3%81%AE%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%80%81%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%81%A8%E5%91%A8%E8%BE%BA%E6%A9%9F%E5%99%A8%E3%81%AE%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E6%A8%A9%3C%2FP%3E%3CP%3E*%20AIPS_0%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20DMA%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9FFIFO%E9%80%81%E4%BF%A1%E3%82%92%E5%82%99%E3%81%88%E3%81%9FLINFlex%20UART%E3%83%A2%E3%83%BC%E3%83%89%3C%2FP%3E%3CP%3E*%20DMA%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9FFIFO%E5%8F%97%E4%BF%A1%E3%82%92%E5%82%99%E3%81%88%E3%81%9FLINFlex%20UART%E3%83%A2%E3%83%BC%E3%83%89%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20ICache%20%E3%81%A8%20DCache%20%E3%81%AF%E3%81%A9%E3%81%A1%E3%82%89%E3%82%82%E3%80%81CACHE_ENABLE%20%E3%83%9E%E3%82%AF%E3%83%AD%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A7%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E*%20%E3%83%9E%E3%82%AF%E3%83%AD%E3%81%AE%E5%80%A4%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%83%91%E3%82%B9%E3%81%A7%E5%A4%89%E6%9B%B4%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E*%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AE%E3%83%97%E3%83%AD%E3%83%91%E3%83%86%E3%82%A3%2F%20C%20%2F%20C%20%2B%2B%E4%B8%80%E8%88%AC%2F%E3%83%91%E3%82%B9%E3%81%A8%E3%82%B7%E3%83%B3%E3%83%9C%E3%83%AB%2F%E3%82%B7%E3%83%B3%E3%83%9C%E3%83%AB%3C%2FP%3E%3CP%3E%E2%80%BB%E5%80%A4%E3%82%921%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E8%B5%B7%E5%8B%95%E6%99%82%E3%81%ABICahce%E3%81%A8DCache%E3%81%8C%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20------------------------------------------------------------------------------%3C%2FP%3E%3CP%3E*%E3%83%86%E3%82%B9%E3%83%88HW%3AMPC5775K-356DS%E3%80%81MPC57xx%E3%83%9E%E3%82%B6%E3%83%BC%E3%83%9C%E3%83%BC%E3%83%89%3C%2FP%3E%3CP%3E*%20MCU%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20PPC5775KMMY3A%200N38M%3C%2FP%3E%3CP%3E*%E7%AB%AF%E6%9C%AB%3A19200-8-%E3%83%91%E3%83%AA%E3%83%86%E3%82%A3%E3%81%AA%E3%81%97-1%E3%82%B9%E3%83%88%E3%83%83%E3%83%97%E3%83%93%E3%83%83%E3%83%88-LINFlexD_0%E3%81%AE%E3%83%95%E3%83%AD%E3%83%BC%E5%88%B6%E5%BE%A1%E3%81%AA%E3%81%97%3C%2FP%3E%3CP%3E*%20Fsys%3APLL0%20266MHz%3C%2FP%3E%3CP%3E*%20Z4%E3%82%B3%E3%82%A2133MHz%3C%2FP%3E%3CP%3E*%20Debugger%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Lauterbach%20Trace32%3C%2FP%3E%3CP%3E*%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20PeMicro%20USB-ML-PPCNEXUS%3C%2FP%3E%3CP%3E%E2%80%BB%E5%AF%BE%E8%B1%A1%3Ainternal_FLASH(%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%83%A2%E3%83%BC%E3%83%89%E3%80%81%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%83%A2%E3%83%BC%E3%83%89)%3C%2FP%3E%3CP%3E*%20EVB%E6%8E%A5%E7%B6%9A%3AJ14.2%E3%80%9CP12.6%20RXD%20LINFlexD_0%E3%83%A1%E3%82%A4%E3%83%B3RS232%E3%81%AB%E6%8E%A5%E7%B6%9A%3C%2FP%3E%3CP%3E*%20J13.2%E3%81%8B%E3%82%89P12.7TXD%20LINFlexD_0%E3%83%A1%E3%82%A4%E3%83%B3RS232%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E********************************************************************************%3C%2FP%3E%3C%2FLINGO-TEASER%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1123618%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E5%85%A8%E8%88%AC%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
評価なし
バージョン履歴
最終更新日:
‎02-11-2016 07:17 AM
更新者:
