Hello world demo fails to build
928件の閲覧回数
ashley_gross
I downloaded the MCU espresso version SDK_2.5.0_TWR-K65F180M and imported the generated file into IAR.  When I make, I get the following errors:
Error[Pe079]: expected a type specifier C:\Users\agross\Work Folders\Desktop\IAR\SDK_2.5.0_TWR-K65F180M\devices\MK65F18\system_MK65F18.c 234
Error[Pe260]: explicit type is missing ("int" assumed) C:\Users\agross\Work Folders\Desktop\IAR\SDK_2.5.0_TWR-K65F180M\devices\MK65F18\system_MK65F18.c 234
Error[Pe141]: unnamed prototyped parameters not allowed when body is present C:\Users\agross\Work Folders\Desktop\IAR\SDK_2.5.0_TWR-K65F180M\devices\MK65F18\system_MK65F18.c 234
Error[Pe130]: expected a "{" C:\Users\agross\Work Folders\Desktop\IAR\SDK_2.5.0_TWR-K65F180M\devices\MK65F18\system_MK65F18.c 234
767件の閲覧回数
danielchen
Hi Ashley:
Please be kindly noted that SDK 2.5 was compiled and tested with IAR 8.32.1.
I would suggest you check your IAR version.
