Amazon-FreeRTOS unavailable in SDK v2.6
601件の閲覧回数
stefanlindblad
sdk 2.6.0 free_rtos
Requested and built SDK v2.6 WITH Amazon-FreeRTOS for MKL1x.
Same SDK is used both for MKL1x and MKL2x but FreeRTOS is only available when creating projects for KL2x.
Will it be reenabled in next update or should I stick with v2.5, where it is available?
Regards, Stefan
タグ(2)
515件の閲覧回数
Alexis_A
Dear Stefan,
You're right, there's a little problem with the SDK from the KL1x, but if you import the SDK from the KL1x a FRDM-KL43 that can be used to develop your project.
If you do this you can select the FreeRTOS option. You will only need to adjust the memory location according to the MCU version are you using.
I hope this helps you.
Alexis Andalon
