I follow the guide to open K64 SDK example, hello world demo, but failed to compile, pls help check it in the attached file.
解決済! 解決策の投稿を見る。
What OS version are you using? It also looks like you may have changed the drive you installed the IDE onto from C: to D: correct?
Anyway, we've seen one similar case to this before with MCUXpresso IDE (though no reports with LPCXpresso IDE, which in this respect should be the same). That was solved by rebooting the PC...
