can't import SDK SDK_2.X_FRDM-KW41Z into MCUXpress
1901167646
when I was load FRDM-KW41Z to MCUXpress IDE, it tell me unable to import SDK, then i uninstall the soft and installation it again but there were the same quation , i can import the usb-kw41z,but can't the frdm-kw41z,could somebody tell me why? it tell me already exists but it not exists.图2.PNG图1.PNG
danielchen
HI SJ:
I would suggest you check the default SDK path
C:\Users\[Yours]\mcuxpresso\01\SDKPackages
Please delete the existing SDK_2.x_FRDM_KW41Z, and try it again.
