Source code of MCUXpresso IDE
480件の閲覧回数
Mahajna
I am using MCUXpresso IDE 11.0.0, I would like to ask if there is a way to reach the source code of it ?
I am working with GIT system that doesn't allow to upload binary files !
I am thinking to upload the source code, then to compile and then to use !
Thanks in advance.
4 返答(返信)
356件の閲覧回数
lpcxpresso_supp
My understanding is that you're asking for source code associated with the EGit plugins available inside the MCUXpresso IDE. That should not be difficult to find - see https://git.eclipse.org/r/plugins/gitiles/egit/egit or/and https://github.com/eclipse-egit
Note that Eclipse-related source code is mostly open-source (EPL licensed) and can be easily inspected by browsing specific repositories. However, MCUXpresso-specific components are based on proprietary source code.
Not sure about the actual limitations you met but I suggest you switch to the latest MCUXpresso IDE (v11.8.1 available, v11.9.0 to be announced soon) that also comes with newer EGit plugins.
MCUXpresso IDE Support
437件の閲覧回数
Hello @Mahajna
Do you asked how to use git with MCUXpresso IDE?
If yes, you can refer to EGit User Guider, open from MCUXpresso IDE as below:
Alice
431件の閲覧回数
Mahajna
Hi @Alice_Yang
Thank you for your reply
This is not what I meant, I asked if there is any way to get the source code of MCUXpresso IDE ?
In other words, is MCUXpresso IDE an open source ?
Thanks in advance.
426件の閲覧回数
Hello @Mahajna
Sorry, no.
Alice
