Hello, When I build the Jlink Debugger, it keeps running and will not break into main. When I suspend the debug, it lands on this error.
For context:
I downloaded the hello world in UART setting instead of semihost and have printf sent to UART with Redlib-nohost-nf.
Andrew
Solved! Go to Solution.
Hi @andrew_ha,
I tested by my side and it works. I tested using the semihost and uart interface.
What is the MCUxpresso version that you are working on?
What is the SDK version that you have?
Mario
Hi @andrew_ha,
Mario
Hello, I think my problem was my pin. I had it set up as uart interface with jp15 shorted, and altering the setting to match that did not work. What I did was I redownloaded the project with the default settings and took off the short pin from jp15 and it works as normal.
