Hello all
I'm looking for Nokia LCD 5110 driver (example) that can be implemented on FRDM K64Z using MCUXpresso.
Shaul
Hi Shaul, hope you're doing well,
In order to interface the Nokia 51150 module, you will need to send SPI commands from your board to the display's controller (PCD8544). Using the document bellow, you will be able to learn how do it:
https://www.sparkfun.com/datasheets/LCD/Monochrome/Nokia5110.pdf
The Software Development Kit (SDK) of your board provides driver examples of the SPI. This tool will let you download it:
https://mcuxpresso.nxp.com/en/welcome
Best regards.
Ruben
There is an example described here:
Snake Game on the FRDM-KL25Z with Nokia 5110 Display | MCU on Eclipse
Zero Cost 84×48 Graphical LCD for the Freedom Board | MCU on Eclipse
It works with Processor Expert (which you can install into MCUXpresso IDE too: MCUXpresso IDE: Installing Processor Expert into Eclipse Neon | MCU on Eclipse and ).
I hope this helps,
Erich
