I have using MCUXpresso IDE v10.3.0.
When I clean my project, "make clean" fails with erro code 87.
make: [makefile:143: clean] Error 87 (ignored)
The cause is that the command line for windows is limited.
https://github.com/gnu-mcu-eclipse/windows-build-tools/issues/3
It will work if you delete the contents of the Debug / Release folder manually , split "clean" in the makefile as follows or create "clean2", but is there a simpler workaround?
# Other Targets
clean:
-$(RM) $(CC_DEPS)-$(RM) $(C++_DEPS)
-$(RM) $(EXECUTABLES)
-$(RM) $(C_UPPER_DEPS)
-$(RM) $(CXX_DEPS)
-$(RM) $(OBJS)
-$(RM) ******.axf
Beset Regards,
T.Kashiwagi
解決済! 解決策の投稿を見る。
unfortunately no there isn't,
as per Liviu Lonesco said there isn't a workaround, unless the one already proposed,
Aldo.
Aldo.
Hi Aldo
Thank you for the advice!
OK... I'll split "clean" in makefile.
Beset Regards,
T.Kashiwagi
A workaround is to shorten directory/folder/project names and also to make the project folder as close to the drive root as possible.
