CVS repository help
CVS repository help
codycox
When setting up a CVS repository in MCUXpresso, what is the best source for getting a CVS repository set up? I don't quite understand the CVS directory listed in the MCUXpresso HELP guide. Say could we get it set up in WinCVS and use that repository location?
I have never set up a CVS repository location so I'm just looking for the best and most simple way to go about setting one up and getting it to work with MCUXpresso IDE. Thank you.
ErichStyger
Senior Contributor V
Just to check: do you really want a CVS repository? Why not using git instead because this (imho) is the right choice and CVS is of the past.
