Properly uninstall mcuxpresso from ubuntu
bp1979
Senior Contributor I
How do I uninstall ubuntu from 21.10 and up?
This trick doesn't work.
bp1979
Found what they meant with "playing around with the filter" ....
$ dpkg --list "*mcu*"
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name               Version      Architecture Description
pc  mcu-link_installer 2            amd64        MCU-Link firmware installer
ii  mcuxpressoide      11.5.1       amd64        MCUXpresso IDE is an Eclipse-based IDE for development of software for NXP LPC and K>
Then remove and purge them both:
$ sudo dpkg --remove --purge mcuxpressoide
$ sudo dpkg --purge mcuxpressoide
$ sudo dpkg --remove mcu-link_installer
$ sudo dpkg --purge mcu-link_installer
And reinstall afterwards.
bp1979
