MCUXpresso - How to link ARM RTOS2 library?
734 次查看
bgraham
I would like to use a RTX library provided by Keil with my MCUXpresso project.
I copied the GCC library file:
C:\Keil_v5\ARM\PACK\ARM\CMSIS\5.4.0\CMSIS\RTOS2\RTX\Library\GCC\libRTX_CM0.a
into my project directory:
E:/Workspace/src/libRTX_CM0.a
In MCUXpresso, I added the libRTX_CM0.a library to the project,
* Properties | C/C++ general | Paths and Symbols | Libraries
* added the library
I get a link error that indicates that the file does not exist.
e:/nxp/mcuxpressoide_10.2.1_795/ide/tools/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/bin/ld.exe: cannot find -lE:/Workspace/src/libRTX_CM0.a
File exists, so what is wrong?
Bruce
550 次查看
bgraham
Yes, I figured that out.
Now I am am trying to figure out why the linker can't find osRtxConfig. I am guessing I need to build the sources, with the desired #defines. I think that is normally done within the Keil IDE.
Do you have a suggestion how that is done when using MCUXpresso?
Bruce
550 次查看
bgraham
I added another directory to my project, and added RTX_Config.c, RTX_Config.h, rtx_lib.c, and rtx_lib.h.
I added the directory to the project's path.
I links now.
Now to sort out the run time problems.
Bruce
550 次查看
converse
Senior Contributor V
When adding a library, you must
1. Specify the raw library name - so if it is called libLibrary.a, you add just Library in the library name
2. Add the path where it can be found separately, so if the library is located at E:/Workspace/src/libRTX_CM0.a, specificy E:/Workspace/src in the library path
