Convolution
1,844件の閲覧回数
LuigiV
Hi I'm using the IMXRT1010 EVK, is there an application example to develop a "low latency partitioned convolution" (c code), using the available DSP library ?
I need to convolve an input stream (from codec) with a Impulse Response file and send the result to the output stream (to codec).
Thank you, Luigi
Thank you, Luigi
1,823件の閲覧回数
Omar_Anguiano
Hello
There is no specific example on the SDK for this operation however on the CMSIS-DSP library documentation you can find a c file for reference on this operation Convolution Example (keil.com)
Omar
1,824件の閲覧回数
Omar_Anguiano
Hello
Omar
