I'm doing my first steps with the RT1010 and the Clock Config Tool in MCUXpresso.
My plan is to run the RT1010 at its maximum clock of 500 MHz. What I have done so far:
Now how can I multiply this clock to get 500 MHz at the core?
What I see at the moment:
The details-view of my clock configuration looks like this at the moment:
So any idea how to configure the clocks properly?
Thank you
解決済! 解決策の投稿を見る。
Hello
Hope you are well.
With PLL2 it won't be possible to reach 500MHz at ARM clock so I suggest you use Enet PLL(PLL6) since it has a fixed frequency of 500MHz.
It is important to comment that for Industrial Grade RT1010 the maximum clock is 400Mhz, for consumer-grade the maximum is 500Mhz.
If you have more questions do not hesitate to ask me.
Omar
Hello
Hope you are well.
Omar
