How to roll back mex_configuration_13.xsd to mex_configuration_12.xsd
897件の閲覧回数
CZ1994
I used to use version 12, but it automatically upgraded to version 13. However, I still want to use version 12. How can I roll back this version.
タグ(1)
3 返答(返信)
875件の閲覧回数
CZ1994
HI Libor,
Thank you for your reply! In fact, I did not directly use Config Tools. I am using S32DS3.5, so I don't know where to turn off automatic updates
Looking forward to your reply
CZ
870件の閲覧回数
liborukropec
then your question should be probably put into this section? https://community.nxp.com/t5/S32-Design-Studio/bd-p/s32ds
Because this is for stand-alone MCUX Config Tools, or general functionality of Config Tools. Their integration into different products should be discussed in particular product forum.
Libor
880件の閲覧回数
liborukropec
once Config Tools are upgraded, there's no way to revert back. The upgrade is not automatic, it is confirmed by the user.
To roll back you have to uninstall the Config Tools and install again. To make sure you won't update again, you can disable the check for a new version in menu "Edit | Preferences":
Libor
