Hello i have a strange problem with my secondary bootloader.
The user app resides from 0x0 - 0x1ffff
The Bootloader from 0x20000 - 0x30000
The user app starts from reset.
The bootloader is called by the user app.
The bootloader erases 0x0 - 0x1ffff and program the sectors with the new data via uart data.
After all data transfered, it makes an reset via wdog.
But the new user app won't start.
To check the data, i read out over swd with an segger j-link.
The data looks okay, and when i erase memory with j-link and program the same
data, that i readout before, it works !!!
So the data programmed through my bootloader are Okay.
Any hints?
Why does a complete chip erase do the job?
Andreas
Which mcu do you use? Do you try to set MSP and PSP to jump?
TIC
- We are following threads for 7 days after the last post, later replies are ignored
we use LPC1769.
The Problem is not the jump, because the bootloader begins at 0x20000 and is called from the
user app.
The Problem is,that after IAP the user App, from 0x00 to 0x1ffff the user app won't start after Reset or Powerup.
The user data after IAP seems to be OK.
Readout via swd -> erase chip -> write back same data -> after reset the user app runs ....
Andreas
Please repost your questions in this link -- https://community.nxp.com/t5/LPC-Microcontrollers/bd-p/lpc
Your case is assigned to kinetis tse. But your product is LPC. So you have to repost.
TIC
