u-boot source code flow for LS2085A QDS Board
1,729 次查看
naveennvn
Hi All,
I'm working on the Freescale Layerscape Processor (LS2085A QDS) Board. I just want to know the u-boot source code flow in the Layerscape2-SDK-20150515-yocto SDK. If anybody has already worked on this, please help me out.
Thanks..
Naveen.
标记 (2)
1,210 次查看
yipingwang
Hello naveennvn,
Please check whether the following information would be helpful for you.
LS2085 CPU
_start : arch/arm/cpu/armv8/start.S, setup exception vector table and each handler.
reset : Setup SCR_EL3=NS|IRQ|FIQ|EA; Initialize CNTFRQ; Enable FP/SIMD; Apply core errata.
  lowlevel_init:
    ccn504_set_qos: Configure CoreLink CCN-504, Cache Coherent Network
    gic_init_secure:
    gic_init_secure_percpu: Configure GIC-500
    secondary_boot_func: Bootup secondary core
  lowlevel_int:  ​Return to reset
reset:
Board side:
_main:
board_init_f: Initialize hardware in flash DDR4
relocate_code: Setup C environment and run in RAM. Copy u-boot code/initialized data to RAM;Setup stack pointer;Clear bss
board_init_r: Initialize hardware in RAM, Flash initialization, init environment, PEX initialization, Console initialize, Enable Ethernet.
Main_loop
_main
Yiping
1,210 次查看
naveennvn
Hi Yiping,
          Now i got the U-boot source code flow. Thanks for your great support.
Naveen
