searching for uefi for ls1046a rdb
marco3181
I saw on the ls1046a rdb that there is an UEFI "bootloader". But when searching on NXP site, there are no images and I can't find any references to UEFI source code.
I search in the tianocore site and in the Linaro EDK2 git but nothing.
Can someone give some hints?
Thank you.
Marc
marco3181
To close this thread, I found what I was looking for on this site:
GitHub - qoriq-open-source/uefi
Marc
marco3181
Marc
Pavel
If your problem is not solved, please create technical case.
Use the following page:
https://community.nxp.com/thread/381898
Pavel Chubakov
marco3181
Just to spread the news, I found this:
GitHub - qoriq-open-source/ls1043a-uefi
Pavel
Look at the following document:
http://cache.nxp.com/assets/documents/data/en/release-notes/QORIQ_SDK_LS1043A_RN.pdf?fsrch=1&sr=3&pa...
Use this document for the LS1046a.
Pavel Chubakov
marco3181
Hello Pavel,
 Thank you for the answer.
I already saw this document but it references in the chapter 49, UEFI, at the page 1138, a git in the freescale sw-stash at the address sw-stash.freescale.net/dnnpi/ls1043a-uefi.git . I can't access to this git repository. It seems that this address no longer exist. Does this repository was moved somewhere else ?
I found a thread at Linaro UEFI that discuss about a ls1043a OpenPlatform patch:  https://lists.linaro.org/pipermail/linaro-uefi/2016-October/002704.html These patches are from a Freescale employee. Are these legit and from the sw-stash git?
 Thank you for your time. Regards
Marc
