ls1021a-iot ST eeprom
1,278件の閲覧回数
williamanderson
I am using the factory kernel and .dtb on the ls1021a-iot board and I am unable to access the ST 64KB eeprom from  i2c interface.
I see DTS entries on i2c0 but the ST device and address 51H are not listed.
based on what i read in the driver documentation I added
a child to the i2c0 node for the eeprom and regenerated the DTB.
eeprom@51{
    compatability="st,24512";
    reg=<0x51>;
    pagesize=128;
But this did not help.  I get an error returned when when I try and read the device.
but i2cdetect seems to see it,
eval1:/home/wanderson# i2cdetect -r 0
WARNING! This program can confuse your I2C bus, cause data loss and worse!
I will probe file /dev/i2c-0 using read byte commands.
I will probe address range 0x03-0x77.
Continue? [Y/n] y
     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
00:          -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- 1c -- -- --
20: -- -- -- -- -- -- -- -- -- -- UU -- -- -- -- --
30: -- -- -- -- -- 35 -- -- -- 39 -- -- -- 3d -- --
40: -- -- -- -- UU UU -- -- 48 -- -- -- UU -- -- --
50: -- 51 -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: 60 -- -- -- -- -- -- -- -- 69 -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
Any suggestions
タグ(1)
0 返答(返信)
