What does "export controlled crypto hardware enabled" meaning?
1,110 次查看
TJAhn
I'm planning to use LS1043A_Auto for my project.
I found out that LS1043A_Auto(Grade 2) only has "export controlled crypto hardware enabled" part...
What is this senetence about? What does it mean?
TJ
5 回复数
873 次查看
Scottrobson
Hii,
These controls are typically imposed by governments to regulate the export of technologies that could have national security implications. In practical terms, it means that if you plan to export or use this processor in certain regions or applications, you may need to comply with specific export regulations and restrictions related to cryptographic technology.
1,006 次查看
khushbur
Hi @TJAhn
It means SEC implements cryptographic algorithms that are subject to United States Government
export control regulations. Please refer ls1043a SECRM section 3.3 SEC Export-Controlled vs. non Export-Controlled Versions for more details.
580 次查看
TJAhn
Thanks for the detailed reply Khushbur.
To confirm my understanding, can you check the reply I wrote?
-> If the P/N contains "E" such as LS1043ABE9PQB, then the SEC is available. Is this right?
1,068 次查看
Irene
NXP Pro Support
NXP Pro Support
Can  you point me to the document which states this?
1,054 次查看
TJAhn
Hello Irene, I found those statements at QorIQ LS1043A_Auto, LS1023A_Auto Data Sheet, section 8.1 Part Numbering Nomenclature.
