Problem with adding packages and flexbuild in LSDK21.08
已解决
跳至解决方案
2,279 次查看
dibyarekha
I am using Ubuntu 20.04. I am trying to build the rootfs for ubuntu lite userland using flexbuilder .
It is building fine with default packages.
But I want to add some other packages like ppp, net-snmp-server etc. In which file I should add the package name such that I will able to get the packages for LS1043ARDB?
As per the user guide of LSDK2108, I trired to add the packages in extra packages list under <flexbuild>/configs/ubuntu/extra_packages_list
But I am not able to add , It is showing its a read only file.
Please Help me
1 解答
2,256 次查看
yipingwang
Please add packages name in variable extra_lite_packages_list in configs/ubuntu/extra_packages_list.
Then execute the following command to rebuild rootfs filesystem.
$ flex-builder -i clean-rfs -r ubuntu:lite
$ flex-builder -i mkrfs -r ubuntu:lite -F
You could use the following command to add write permission.
$ chmod a+w configs/ubuntu/extra_packages_list
在原帖中查看解决方案
2 回复数
2,257 次查看
yipingwang
2,251 次查看
dibyarekha
Thank you so much for your guidance. I got it
