I have a SD card with bl2_sd.pbl and fip.bin. During LS1043ARDB's SD card based bootup, the following messages are observed. I am unable to use any ethernet interface in uboot. How do I fix this?
MMC read: dev # 0, block # 18944, count 128 ...
Not a microcode
Flash: 128 MiB
NAND: 512 MiB
MMC: Loading Environment from MMC... OK
EEPROM: NXID v1
In: serial
Out: serial
Err: serial
SEC0: RNG instantiated
Net:
MMC read: dev # 0, block # 18432, count 128 ...
Fman1: Data at 00000000f7a2b280 is not a firmware
Fman1: Data at 00000000f7a3b290 is not a firmware
Fman1: Data at 00000000f7a4b2a0 is not a firmware
Fman1: Data at 00000000f7a5b2b0 is not a firmware
Fman1: Data at 00000000f7a6b2c0 is not a firmware
Fman1: Data at 00000000f7a7b2d0 is not a firmware
Fman1: Data at 00000000f7a8b2e0 is not a firmware
Fman1: Data at 00000000f7a9b2f0 is not a firmware
Fman1: Data at 00000000f7aab300 is not a firmware
Fman1: Data at 00000000f7abb310 is not a firmware
Fman1: Data at 00000000f7acb320 is not a firmware
Fman1: Data at 00000000f7adb330 is not a firmware
Fman1: Data at 00000000f7aeb340 is not a firmware
Fman1: Data at 00000000f7afb350 is not a firmware
No ethernet found.
