LS1043AQDS - DRIVERS - I2C
carlos-m-ribeiro
It is possible using the profile ls1043aqds_qspi_defconfig and include in the u-boot binary the routines from drivers/i2c/i2c_core.c to use in new commands that were placed in common u-boot folder?
Thank you.
Pavel
Often u-boot scripts are use for adding new command in u-boot.
Adding new setting to the ls1043aqds_qspi_defconfig file and new functions to the I2C driver also is possible.
