LS1024A SPI inquiry
LS1024A SPI inquiry
h201668
May I ask about the SPI interface on the LS1024A?
The SPI interface is similar to the LS1024ARDB Schematic.
Related URLs:
https://www.nxp.com/products/processors-and-microcontrollers/arm-processors/layerscape-processors/la...
The SPI interface does not work.
SCLK and SPI_SS1 are output as HIGH on the SPI interface.
There is a symptom that the clock does not come out from the SCLK pin and the chip select does not work on the CS pin.
What can I do to resolve these symptoms?
