LLDPUG yocto implementation problem
jackho
We are now implementation with LLPDUG 5.15.71 on LX2160ARDB_REV2
Some questions below want to check with you.
1. About meta-layer, I saw meta-qoriq, meta-freescale and meta-nxp-desktop, I am a little confused about  what is different between these layers, which layer is specific for lx2160ardb platform?
2. About u-boot bb files, I saw the below path both have u-boot bb files, how do I confirm which one I am using for lx2160ardb_rev2?
./meta-freescale/recipes-bsp/u-boot/u-boot-qoriq_2021.04.bb
./meta-qoriq/recipes-bsp/u-boot/u-boot-qoriq_2022.04.bb
3. I am trying to modify rcw for our hardware customization and using devtool to generate patch, but it seems the patch does not apply, I saw original rcw_git.bb is in meta-freescale, but meta-qoriq also has rcw_git.bbappend file and I put the patch on meta-qoriq/recipes-bsp/rcw, but the patch didn't apply,
Thanks.
BR,
Jack Ho
yipingwang
1.The layer meta-qoriq contains the latest Yocto SDK changes of Layerscape;
  • And these changes will upstream from meta-qoriq to meta-freescale after NXP BSP releases.
  • NXP does not own the layer meta-freescale, which is belong to Yocto community. It contains some customization of other contributors using our SoCs.
meta-nxp-desktop contains recipes for Ubuntu filesystem.
meta-qoriq+meta-freescale is specific for lx2160ardb platform.
2. You should use meta-qoriq/recipes-bsp/u-boot/u-boot-qoriq_2022.04.bb
3. Please try this method.
$ source build_lx2160ardb-rev2/SOURCE_THIS
$ bitbake rcw -c patch -f
Please go to rcw source folder tmp/work/lx2160ardb_rev2-fsl-linux/rcw/git-r0/git/ and apply your patch and do some modifications.
$ patch -p1 <your_patch>
Rebuild rcw with the following command.
$ bitbake rcw -c compile -f
$ bitbake rcw
yipingwang
$ bitbake rcw
