I cannot seem to find anywhere the document QorIQ LS2080A SDK 1.0 Deployment Guide
895 次查看
emmanouilkafetz
, or the QorIQ LS2080A SDK 1.0 Quick Start Guide file, are they somewhere located I have already downloaded the LS2080A-SDK-1-0.rar, but I cannot locate them!??
I try to follow the reference guide, but where is the the aforementioned files?
标记 (1)
709 次查看
Pavel
Use information for the SDK 1.8. The QorIQ LS2080A SDK 1.0 uses the same commands as the SDK 1.8.
Load the “QorIQ SDK v1.8 Info Center.pdf” file using the following link:
https://freescaleesd.flexnetoperations.com/337170/767/8926767/QorIQ%20SDK%20v1.8%20Info%20Center.pdf...
Pavel
709 次查看
emmanouilkafetz
Greetings Pavel thank you for your response, but the link provided prints out that an error has occured, from a quick google search i have found the
QorIQ Linux SDK v1.9 is this correct link?
Thank you
