I'm buiding images for LS2088ardb by using Yocto command "bitbake fsl-image-networking"
Now I load the dtb in the QEMU but can't boot into kernel and step by step SOP as below:
$ qemu-system-aarch64 \
-smp 8 \
-machine type=virt,gic-version=3 \
-m 2048 \
-cpu cortex-a72 \
-kernel Image \
-serial tcp::4446,server,telnet \
-drive if=none,file=fsl-image-networking-ls2088ardb.rootfs-20240711074828.ext4,id=foo,format=raw \
-device virtio-blk-device,drive=foo \
-append 'root=/dev/vda rw console=ttyAMA0,115200 rootwait earlyprintk' \
-monitor stdio
Output as belowQEMU 4.2.1 monitor - type 'help' for more information
(qemu) qemu-system-aarch64: -serial tcp::4446,server,telnet: info: QEMU waiting for connection on: disconnected:telnet:0.0.0.0:4446,server
telnet 0.0.0.0 4446I can success to boot into kernel
Trying 0.0.0.0...
Connected to 0.0.0.0.
Escape character is '^]'.
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd083]
[ 0.000000] Linux version 6.6.23-gb586a521770e (oe-user@oe-host) (aarch64-fsl-linux-gcc (GCC) 13.2.0, GNU ld (GNU Binutils) 2.42.0.20240216) #1 SMP PREEMPT Fri Jun 7 13:15:57 UTC 2024
[ 0.000000] KASLR disabled due to lack of seed
[ 0.000000] Machine model: linux,dummy-virt
ls2088ardb login: root
root@ls2088ardb:~#
$ qemu-system-aarch64 \Output as below
-smp 8 \
-m 2048 \
-cpu cortex-a72 \
-kernel Image \
-dtb fsl-ls2088a-rdb.dtb \
-monitor stdio
Trying 0.0.0.0...
It stay here and can't boot into kernel-d int,cpu_reset
CPU Reset (CPU 0)Here is my build image folder
R00=00000000 R01=00000000 R02=00000000 R03=00000000
R04=00000000 R05=00000000 R06=00000000 R07=00000000
R08=00000000 R09=00000000 R10=00000000 R11=00000000
R12=00000000 R13=00000000 R14=00000000 R15=00000000
PSR=40000000 -Z-- A usr26
CPU Reset (CPU 1)
CPU Reset (CPU 2)
CPU Reset (CPU 3)
CPU Reset (CPU 4)
CPU Reset (CPU 5)
CPU Reset (CPU 6)
CPU Reset (CPU 7)
CPU Reset (CPU 0)
PC=0000000000000000 X00=0000000000000000 X01=0000000000000000
X02=0000000000000000 X03=0000000000000000 X04=0000000000000000
X05=0000000000000000 X06=0000000000000000 X07=0000000000000000
X08=0000000000000000 X09=0000000000000000 X10=0000000000000000
X11=0000000000000000 X12=0000000000000000 X13=0000000000000000
X14=0000000000000000 X15=0000000000000000 X16=0000000000000000
X17=0000000000000000 X18=0000000000000000 X19=0000000000000000
X20=0000000000000000 X21=0000000000000000 X22=0000000000000000
X23=0000000000000000 X24=0000000000000000 X25=0000000000000000
X26=0000000000000000 X27=0000000000000000 X28=0000000000000000
X29=0000000000000000 X30=0000000000000000 SP=0000000000000000
PSTATE=400003c5 -Z-- EL1h
CPU Reset (CPU 1)
CPU Reset (CPU 2)
CPU Reset (CPU 3)
CPU Reset (CPU 4)
CPU Reset (CPU 5)
CPU Reset (CPU 6)
CPU Reset (CPU 7)
Exception return from AArch64 EL1 to AArch64 EL1 PC 0x423790d0
Taking exception 1 [Undefined Instruction]
...from EL1 to EL1
...with ESR 0x0/0x2000000
...with ELR 0xffff800080027b20
...to EL1 PC 0xffff800080011200 PSTATE 0x3c5
boot_ls2088ardb_lts_6.6.tgz
core-image-minimal-ls2088ardb.rootfs-20240711074828.cpio.gz
core-image-minimal-ls2088ardb.rootfs-20240711074828.cpio.gz.u-boot
core-image-minimal-ls2088ardb.rootfs-20240711074828.manifest
core-image-minimal-ls2088ardb.rootfs-20240711074828.spdx.tar.zst
core-image-minimal-ls2088ardb.rootfs-20240711074828.tar.gz
core-image-minimal-ls2088ardb.rootfs-20240711074828.testdata.json
core-image-minimal-ls2088ardb.rootfs.cpio.gz->core-image-minimal-ls2088ardb.rootfs-20240711074828.cpio.gz
core-image-minimal-ls2088ardb.rootfs.cpio.gz.u-boot->core-image-minimal-ls2088ardb.rootfs-20240711074828.cpio.gz.u-boot
core-image-minimal-ls2088ardb.rootfs.manifest->core-image-minimal-ls2088ardb.rootfs-20240711074828.manifest
core-image-minimal-ls2088ardb.rootfs.spdx.tar.zst->core-image-minimal-ls2088ardb.rootfs-20240711074828.spdx.tar.zst
core-image-minimal-ls2088ardb.rootfs.tar.gz->core-image-minimal-ls2088ardb.rootfs-20240711074828.tar.gz
core-image-minimal-ls2088ardb.rootfs.testdata.json->core-image-minimal-ls2088ardb.rootfs-20240711074828.testdata.json
fitImage->fitImage--6.6.23+git0+b586a52177-r0-ls2088ardb-20240711074828.bin
fitImage-core-image-minimal-ls2088ardb.rootfs--6.6.23+git0+b586a52177-r0-ls2088ardb-20240711074828.bin
fitImage-core-image-minimal-ls2088ardb.rootfs-ls2088ardb->fitImage-core-image-minimal-ls2088ardb.rootfs--6.6.23+git0+b586a52177-r0-ls2088ardb-20240711074828.bin
fitImage-its--6.6.23+git0+b586a52177-r0-ls2088ardb-20240711074828.its
fitImage-its-core-image-minimal-ls2088ardb.rootfs--6.6.23+git0+b586a52177-r0-ls2088ardb-20240711074828.its
fitImage-its-core-image-minimal-ls2088ardb.rootfs-ls2088ardb->fitImage-its-core-image-minimal-ls2088ardb.rootfs--6.6.23+git0+b586a52177-r0-ls2088ardb-20240711074828.its
fitImage-its-ls2088ardb->fitImage-its--6.6.23+git0+b586a52177-r0-ls2088ardb-20240711074828.its
fitImage-linux.bin--6.6.23+git0+b586a52177-r0-ls2088ardb-20240711074828.bin
fitImage-linux.bin-ls2088ardb->fitImage-linux.bin--6.6.23+git0+b586a52177-r0-ls2088ardb-20240711074828.bin
fitImage-ls2088ardb.bin->fitImage--6.6.23+git0+b586a52177-r0-ls2088ardb-20240711074828.bin
fsl-image-networking-ls2088ardb.rootfs-20240711074828.cpio.gz
fsl-image-networking-ls2088ardb.rootfs-20240711074828.cpio.gz.u-boot
fsl-image-networking-ls2088ardb.rootfs-20240711074828.manifest
fsl-image-networking-ls2088ardb.rootfs-20240711074828.spdx.tar.zst
fsl-image-networking-ls2088ardb.rootfs-20240711074828.tar.gz
fsl-image-networking-ls2088ardb.rootfs-20240711074828.testdata.json
fsl-image-networking-ls2088ardb.rootfs.cpio.gz->fsl-image-networking-ls2088ardb.rootfs-20240711074828.cpio.gz
fsl-image-networking-ls2088ardb.rootfs.cpio.gz.u-boot->fsl-image-networking-ls2088ardb.rootfs-20240711074828.cpio.gz.u-boot
fsl-image-networking-ls2088ardb.rootfs.ext4->fsl-image-networking-ls2088ardb.rootfs-20240711074828.ext4
fsl-image-networking-ls2088ardb.rootfs.manifest->fsl-image-networking-ls2088ardb.rootfs-20240711074828.manifest
fsl-image-networking-ls2088ardb.rootfs.spdx.tar.zst->fsl-image-networking-ls2088ardb.rootfs-20240711074828.spdx.tar.zst
fsl-image-networking-ls2088ardb.rootfs.tar.gz->fsl-image-networking-ls2088ardb.rootfs-20240711074828.tar.gz
fsl-image-networking-ls2088ardb.rootfs.testdata.json->fsl-image-networking-ls2088ardb.rootfs-20240711074828.testdata.json
fsl-ls2088a-qds--6.6.23+git0+b586a52177-r0-ls2088ardb-20240711074828.dtb->fsl-ls2088a-qds.dtb
fsl-ls2088a-qds.dtb
fsl-ls2088a-qds-ls2088ardb.dtb->fsl-ls2088a-qds.dtb
fsl-ls2088a-rdb--6.6.23+git0+b586a52177-r0-ls2088ardb-20240711074828.dtb->fsl-ls2088a-rdb.dtb
fsl-ls2088a-rdb.dtb
fsl-ls2088a-rdb-ls2088ardb.dtb->fsl-ls2088a-rdb.dtb
Image->Image--6.6.23+git0+b586a52177-r0-ls2088ardb-20240711074828.bin
Image-ls2088ardb.bin->Image--6.6.23+git0+b586a52177-r0-ls2088ardb-20240711074828.bin
ls2088ardb_boot.scr
modules--6.6.23+git0+b586a52177-r0-ls2088ardb-20240711074828.tgz
modules-ls2088ardb.tgz->modules--6.6.23+git0+b586a52177-r0-ls2088ardb-20240711074828.tgz
u-boot.bin->u-boot-tfa-2024.04++fslgit-r0.bin
u-boot.bin-tfa->u-boot-tfa-2024.04++fslgit-r0.bin
u-boot.bin-tfa-secure-boot->u-boot-tfa-secure-boot-2024.04++fslgit-r0.bin
u-boot-ls2088ardb.bin->u-boot-tfa-2024.04++fslgit-r0.bin
u-boot-ls2088ardb.bin-tfa->u-boot-tfa-2024.04++fslgit-r0.bin
u-boot-ls2088ardb.bin-tfa-secure-boot->u-boot-tfa-secure-boot-2024.04++fslgit-r0.bin
u-boot-qoriq-initial-env-ls2088ardb-tfa->u-boot-qoriq-initial-env-ls2088ardb-tfa-2024.04++fslgit-r0
u-boot-qoriq-initial-env-ls2088ardb-tfa-secure-boot->u-boot-qoriq-initial-env-ls2088ardb-tfa-secure-boot-2024.04++fslgit-r0
u-boot-qoriq-initial-env-tfa->u-boot-qoriq-initial-env-ls2088ardb-tfa-2024.04++fslgit-r0
u-boot-qoriq-initial-env-tfa-secure-boot->u-boot-qoriq-initial-env-ls2088ardb-tfa-secure-boot-2024.04++fslgit-r0
You cannot emulate the device in a PC. This would need to create a new QEMU image that works with all the modules of the LS2088A and we do not have any image like that.
What I understood was to simulate an Arm OS with QEMU in the board and you can for sure do that.
