Fetch failure for URL 'git://sw-stash.freescale.net'
mdanilau
I'm trying to rebuild the linux kernel for LS1021A with QorIQ-SDK-V1.8.
With 'bitbake -c menuconfig virtual/kernel' i deactivated all freescale network kernel drivers and activated AX88772A network driver.
Duting executing 'bitbake virtual/kernel' i get errors like
ERROR: Fetcher failure: Fetch command failed with exit code 128, output:
Cloning into bare repository '/home/mdu/Freescale-Linux-SDK-for-LS1021A-Rev2-v0.4-20150803-yocto/sources/git2/sw-stash.freescale.net.scm.dnnpi.ls1-linux.git'...
fatal: unable to access 'http://sw-stash.freescale.net/scm/dnnpi/ls1-linux.git/': Could not resolve host: sw-stash.freescale.net
ERROR: Function failed: Fetcher failure for URL: 'git://sw-stash.freescale.net/scm/dnnpi/ls1-linux.git;branch=LS1-SDK-Rev2.0;protocol=http'. Unable to fetch URL from any source.
ERROR: Logfile of failure stored in: /home/mdu/Freescale-Linux-SDK-for-LS1021A-Rev2-v0.4-20150803-yocto/build_ls1021atwr_release/tmp/work/ls1021atwr-fsl-linux-gnueabi/linux-ls1/3.12-r0/temp/log.do_fetch.18550
ERROR: Task 2 (/home/mdu/Freescale-Linux-SDK-for-LS1021A-Rev2-v0.4-20150803-yocto/meta-fsl-arm/recipes-kernel/linux/linux-ls1_3.12.bb, do_fetch) failed with exit code '1'
The question is: what i'm doing wrong?
