Error building fsl-image-full in SDK 1.7 for ls1021aqds
1,681 次查看
sidharthkodikal
I get an error in the alsa-utils recipe (which I don't care about) when building the SDK 1.7.
ERROR: Task 2239 (/media/wd_3tb/yocto/QorIQ-SDK-V1.7-20141218-yocto/poky/meta/recipes-multimedia/alsa/alsa-utils_1.0.27.2.bb, do_configure) failed with exit code '1'
I'm attaching a log with the verbose output.
Is this a known issue or perhaps something with my environment (Ubuntu 12.04. Building from the SDK source ISO.)?
Sidharth
标记 (3)
4 回复数
1,052 次查看
setugupta
I got the solution
bitbake -c cleanall ncurses
bitbake -c cleanall alsa-utils
bitbake -c build ncurses
bitbake -c build alsa-utils
bitbake <your target>
1,052 次查看
setugupta
HI Sidharth
I am facing the same problem.
If you have solved the issue please suggest me to solve this.
Thanks in advance
1,052 次查看
yipingwang
Hello Sidharth Kodikal,
It seems that there is a dependence missing problem in your build environment, please run "bitbake alsa-utils" first, then continue to perform you build, this command will force necessary dependent packages deployed in your build environment.
Please feel free to let me know, if your problem remains.
Yiping
1,052 次查看
setugupta
Hi Yiping Wang
i have faced the same problem , and tried the solution you suggested but dint got the problem solved.
ERROR: Task 5 (/home/setu/var-som-mx6-daisy-v7/sources/poky/meta/recipes-multimedia/alsa/alsa-utils_1.0.27.2.bb, do_configure) failed with exit code '1'
here is the error i am facing.
