Does the pcie network port on LS1043 support DPDK?
Jack2023
We are using the LS1043 chip,  and we have expanded 4 network ports using Intel  i350(pcie).
Currently, the motherboard has a total of 10 network ports, 6 dpaa port (LS1043), and 4 pcie port (i350),our applications are all based on DPDK, and all these ports must work in DPDK mode.
Can LSDK support both DPAA  and PCIE ports working simultaneously in DPDK mode? Is there a relevant  manual available?
thanks.
Tags (3)
Irene
NXP Pro Support
NXP Pro Support
i350 ports and DPAA ports can work together on the LS1043A DPDK. You only need to
insmod igbuio.ko
before running dpdk.
echo "vendorID deviceID" > /sys/bus/pci/drivers/igb_uio/new_id
Jack2023
Thank you for your reply.  All of our network ports have already started running in dpdk mode
Irene
NXP Pro Support
NXP Pro Support
insmod igbuio.ko
Irene
NXP Pro Support
NXP Pro Support
I will take a look at this issue.
