How to confirm which boot loader is enabled in ls1046ardb uboot whether default/UEFI/SECBOOT/atf ?
1,125 次查看
srinivasa
How to confirm which boot loader is enabled in ls1046ardb uboot whether default/UEFI/SECBOOT/atf  in lsdk20.04?. firmware is building for all.
1 回复
1,047 次查看
Irene
NXP Pro Support
NXP Pro Support
I don't quite understand your question.
Flexbuild can separately build each component, or it can automatically build all the components; it generates the composite firmware(containing RCW, U-Boot/UEFI, PHY firmware, kernel image, dtb, initrd) and NXP LSDK userland (containing the specified
packages and application components).
Look at section 5.4.4.3 LS1046ARDB of the Layerscape Software Development Kit User Guide, Rev. 20.04, 04/2020 document.
