CodeWarrior TAP and GDB for LS2084 debug
704 次查看
miha_at_work
Hello.
It is possible to debug LS2084 by Codewarrior TAP using only GDB (without CodeWarrior software)?
标记 (3)
597 次查看
alexander_yakov
No, CodeWarrior TAP can not be used with GDB.
Previously, there was a project using CodeWarrior TAP with GDB, but this project is no longer supported.
598 次查看
alexander_yakov
597 次查看
miha_at_work
Ok. Thank you.
