Cannot boot LX2160A-RDB
2,145 次查看
diljithka
I am currently using LX2160A-RDB board . The board is failing in the U-boot sequence immediately after detecting the DDR.("Waiting for D_INIT timeout. Memory may not work."). I tried with different DDR with the same clock frequency,but still the error is showing .Is there any suggestion in why this is happening?? How can this issue be  resolved?image.png
16 回复数
472 次查看
Madhan
Do you guys find any Solution i am also getting same error?
i used to work fine but now it is not working.
2,140 次查看
ufedor
Is the board brand new?
I'm asking because Rev.1 silicon is obsolete and is not supported anymore.
2,132 次查看
diljithka
The board is not Rev.1 silicon.
2,127 次查看
ufedor
2,124 次查看
diljithka
Really sorry for the mistake.
Actually this board was working fine few days back. I am not really understanding what has happened to the board.we are really stuck with this issue. Is there any way that you can bring me out of this. we really cannot move forward without solving this DDR issue.
2,116 次查看
ufedor
Please try to re-seat the DDR SDRAM modules.
2,105 次查看
diljithka
We have tried changing the DDR modules multiple times but still the board is showing the same issue
2,100 次查看
ufedor
Please use CodeWarrior and re-program composite firmware binary image available at:
https://lsdk.github.io/components.html
section LSDK IMAGES (for silicon Rev1.0 use LSDK 20.04 or earlier).
2,086 次查看
diljithka
In the link provided https://lsdk.github.io/components.html there is no image for REV 1.
So i tried using the composite image provided in the lsdk 20.04 document.Screenshot from 2021-02-18 16-36-43.pngI had followed the steps to recover the board using the
CodeWarrior tool, see section " 8.6 Board Recovery " in ARM V8 ISA, Targeting Manual.
But still i am not able to boot the board. This is the error which i am getting.
2,067 次查看
ufedor
Use drop-down selector at the top of the page:
2,057 次查看
diljithka
Thanks for the support. I had downloaded the 19.09 image.and tried flashing using code warrior studio.Still i am getting the error.
  • The image which i used is :  firmware_lx2160ardb_uboot_xspiboot.img.
  • And have flashed this image using code warrior studio.
  • Then power-cycled the board
  • On power-On the board get stuck here
  • Please correct if the steps which i followed is wrong or if i had missed any steps .
  • How can these issues be solved?
2,053 次查看
ufedor
Check all on-board configuration switches and set them into default positions.
2,049 次查看
diljithka
On board switches are already set to default as per the document.
2,045 次查看
ufedor
Firmware which you programmed has RCW setting 2900 MT/s data rate, but installed modules support only 2600.
Please try attached firmware.
2,041 次查看
diljithka
I used the attached  firmware , but still board didn't came up.
标记 (1)
2,029 次查看
ufedor
According to the log the last firmware image is the same as it was originally.
It seems that the processor was damaged (may be by a ESD).
